> Planar Artifacts, (Item Stat Cards)
сообщение 19.8.2009, 14:40
Приветствую. Я разработал новый сет Item Stat Cards - Planar Artifacts. В связи с тем что в Treasure Trove - предметы обычные, я решил создать сет где все предметы уникальны (см. ниже) и обладают (в отличие от Treasure Trove) весьма полезными свойствами, но в связи с этим и Point Cost этих предметов довольно высок. P.S. Ногами попрошу не пинать так как я это разрабатывал для себя и тех с кем играю wink.gif
Итак..
Planar Artifacts
Unique: Warband can include only one Unique item.
Soulkeeper Amulet (Unique)
Level 10-19non-Evil
Keep Soul: Immediate, when this creature would be destroyed: it has 15 HP remaining instead.
Soul Defender: Can be used only by Living creatures.
+29 points
Glove of Betrayer (Unique)
Level 7-19Evil
❑❑ Betray: (Allies only) As a free action: attack ally with [M] or [R] attack; that attack is automatic hit and critical hit; if ally is destroyed it is considered to have 0 point cost for determine VP.
Defiance: (if Betray was used) Whenever an ally attacks this creature: +3 Attack and +10 Damage on that attack.
+26 points
Steel Face of Madness (Unique)
Level 10-19Evil • Undead
Firstborn Fear: (Aura 1) Enemies have -4 Attack against this creature whenever starting a turn in aura; affects creatures that immune to Fear.
+29 points
Vessel of Blood (Unique)
Level 8-21Any
Bloody Earth: Use when this creature is destroyed: all squares adjacent to this creature and this creature's space count as Blood Rock until end of battle.
+21 points
Torch of Inquisition (Unique)
Level 6-18Any
Soul Destructor: (Living targets only) Whenever this creature's [M] or [R] attack reduces a Living target to 0 HP or fewer: that target is considered to have 0 HP until end of battle.
Mark of Inquisitor: +2 Attack against Undead targets.
+24 points
Holy Aspen Stake (Unique)
Level 10-18Good
Pierce the Heart: (Vampire targets only) Use when this creature declares a [M] attack against a Vampire target: if that attack hits it becomes a critical hit and target gains -4 Attack (save ends). RECHARGE if that attack misses.
Mark of Hunter: +2 Attack and +5 Damage against Vampire targets.
+28 point
Blindfold of Predator (Unique)
Level 13-21Wild
The Fifth Sense: This creature has Blindsight and is immune to attack actions and powers with Gaze in their name.
Hunter's Challenge: +3 Attack against Shadow and Hide creatures.
+34 points
Vampiric Claw (Unique)
Level 9-20Evil
Vampiric Touch: (Living targets only) Use when this creature's [M] attack hits a Living target: this creature heals HP equivalent to damage dealt.
Bloodthirsty 5: +5 [M] Damage against Bloodied targets.
+29 points
Avenger's Ring (Unique)
Level 8-19Any
Revenge: Use when an enemy destroyed your ally: +3 Attack and +10 Damage against that enemy until end of battle.
+27 points
Black Glove of Decay (Unique)
Level 10-21Any
❑❑ Touch of Decay: (Undead targets only) Use when this creature's [M] attack hits an Undead target level 9 or lower: -5 HP at start of the target's turn until end of battle.
Scholar of Decay: If used by an Undead creature, Touch of Decay can target Undead creatures level 11 or lower.
+31 points
Diadem of Sunlight (Unique)
Level 11-21Good
Sunlight: (Aura 2) All Shadow and Hide creatures within this aura grants combat advantage to attackers; all creatures that have Vulnerability to radiant Damage gains 5 radiant Damage whenever starting a turn in aura.
+32 points
Necklace of Unseen (Unique)
Level 9-17Any
Unseen: This creature has Blindsight, Phasing, Insubstantial.
Radiant Weakness: This creature has Vulnerable 10 Radiant.
+17 points
Spiked Crown (Unique)
Level 8-20Evil
Tyranny: (Aura 1) All squares within this aura count as Zone of Death and as difficult terrain, affects creatures that immune to auras; this creature and it's allies are not affected by aura effects.
Unruly: Can be used only by creature with highest Champion Rating in the warband.
+28 points
Cloak of Shadows (Unique)
Level 7-18
Dance of Shadows: This creature has Hide; and Conceal 11 against all non-[M] attacks.
Nature of Shadows: Can be used only by Unaligned creatures.
+25 points
Crystal of Elemental Resistance (Unique)
Level 1-30Any • Elemental
Elemental Resistance: This creature has Resist 10 Thunder, Cold, Fire, Lightning.
+31 points
Mirror Shield (Unique)
Level 9-19Any
❑❑ Reflect: Use when this creature gains radiant Damage: attacker gains radiant Damage equivalent to radiant Damage dealt.
+28 points
сообщение 19.8.2009, 14:46
Я так подозреваю вместо значков - ✦ должно стоять [ ] ?
Для атак вставлены иконки, если на блоке смайлов нажать следующие
можно увидеть вот такое :
надо кстати еще ranged добавить
сообщение 19.8.2009, 14:47
Неа, это именно ✦. В Treasure Trove точно такие же разделяют Level существа и нужные Keywords.
На счет иконок: а может есть смысл их сделать gif'ами без белого фона?
сообщение 19.8.2009, 14:52
Если можешь сделай, я заменю.
Мне все таки кажется это - ✦ ошибка кодировки .
сообщение 19.8.2009, 14:54
На счет иконок: чтобы они были с прозрачным фоном и имели хороший вид надо векторизовать их, а затем сохранить как gif. Это довольно затруднительно, но я попробую сделать..
сообщение 19.8.2009, 17:25
ромбик это типо так - Прикрепленное изображение ? тоже могу добавить в набор
сообщение 19.8.2009, 17:30
biggrin.gif Это именно ромбик бубновый! С вогнутыми краями.. Ну вот глянь:
сообщение 19.8.2009, 17:59
Ну можно и такой сделать ))
сообщение 20.8.2009, 19:53
вау. просто вау. вот это качественный продукт, товарищи smile.gif.
очень понравилось. много оригинальных идей, в том числе таких, которые могу реально быть использованы в игре (в отличие от ТТ1, среди которых тока хил пот работает smile.gif).
есть некоторые замечания, но прежде, чем их высказать, я хочу знать:
1. каким образом шмотки оценивались?
2. по какому принципу выбирался уровень кричи, способной носить шмотку?
3. был ли реальный плейтест в форматах стандарт и эпик ассаулт?
из общих комментариев: в строке условий должен стоять алайнмент и кейворды. ливинг, нон-ивил, нон-гуд, медиум сайз и т.д. слишком усложняют систему, и от этого необходимо избавиться в первую очередь.
почему не указывается размер существа на шмотках? потому что шмотки могут быть разных размеров smile.gif. у тебя, конечно, они уникальные, однако, насколько я знаю, никто не мешает использовать шмотки размеров, отличных от размера кричи. конечно, дайр медведь с хил потом и летучая мышь фамилиар с магической стеной выглядят по-идиотски, но механика игры такова, и размеры крич на карточках не присутствуют.
пока всё. после ответа на мои вопросы можно начать общее обсуждение по поводу доработки карточек. думаю, этот сет не грех будет представить гильдмастерам, и даже если его не используют целиком, то могут позаимствовать идеи для следующего сета шмоток.
сообщение 20.8.2009, 20:48
1. Чем круче шмотка - тем выше цена. Если крутая шмотка, но условий много - цена ниже и т.п.
2. Я расчитывал что когда кобольд или летучая мышь будет носить Red Glove of Doom или что то подобное это будет как то, мягко говоря странно.
3. Нет. Да и игроков в моем городе - насколько мне известно всего 2.. Я и мой друг, который не может очень часто играть...
Medium Size можно убрать, в принципе. Living - я считаю важным Keyword'ом так как, на пример: Diadem of Sunlight все же больше ассоциируется с живим обладателем, чем с мертвым.. Ровно как и Soulkeeper Amulet... На счет non-Good и non-Evil - нет же слова синонима в правилах для существ - нейтралов.. Да и Cloak of Shadows я представляю как атрибут наемника, который работает с тем кто ему выгоден.. да и тень все же это не тьма и не свет тоесть это нечто среднее.. нейтральное..
ИМХО.
Пока что уберу Medium Size.. отовсюду.. и попробую пересмотреть киворды. Было бы удобнее если бы Вы предложили изменить киворды у конкретных предметов.
Надо бы довести до ума Level'ы. Только при условии что минимальный Level будет 5-7 (за исключением Crystal of Elemental Resistance).
сообщение 20.8.2009, 21:16
В помощь создателю от мэтра Tien
Набор бланков и шрифт
сообщение 20.8.2009, 21:21
Скай - а это официальные шаблоны? Или "home made" выдранные? А то, если оформлять, то делать это надо с полученными от гильдии шаблонами и шрифтами.. Если уж на то пошло... ИМХО.
это слишком абстрактный ответ smile.gif. да и подход тоже - можно было так и сказать: от балды smile.gif. просто я думал, у тебя есть система. а нет, значит над стоимостью надо работать.
ИМХО.
тут дело не в имхо, а механике игры. я понимаю, что при создании этих шмоток ты исходил из ролевых и логических соображений. но это не всегда помогает органично вписаться в механику.
Living - это не кейворд, хоть ты тресни. можно вывернуться следующим образом: носить её может и не ливинг, но у него это не будет работать. типа, в тексте самой шмотки: use if this creature is living creature.
non-Good и non-Evil - почему бы не ужесточить до Ивил и Гуд соответственно? а для нейтралов есть слово (хотя тоже не используется в условиях для итемов) - unaligned. на крайняк, опять же, в тексте карты уточнять, кто может применять.
не вижу проблемы с минимальным левелом, а вот с максимальным, очевидно, полом, ибо практически у всех он выше крыши. этот момент надо прорабатывать параллельно с ценой предметов.
позже напишу комментарии конкретно к абилкам и моё видение их оценки.
сообщение 20.8.2009, 21:23
согласен с тобой. никому не рекомендую делать на тяп-ляп-шаблоне с нарушением копирайтов. для нашего применения, в принципе, покатит, но если идём на предложение гильдмастерам, то лучше просто тексту выдать.
Выдранные, не уверен что нам их сразу так дадут в гильдии, мне кажется данный комплект вполне подойдет для первого раза и для представления на суд гильдмастеров.
сообщение 20.8.2009, 21:25
Xou как гильд мастер нашего региона может попросить у гильды в принципе.
сообщение 20.8.2009, 21:41
Не от "балды", а из "логических соображений". wink.gif Если чесно - мы не знаем как Point Cost гильдия присваивает своим объектам. smile.gif
На счет Living и нейтралов думаю можно сделать так: добавить предмету абилку, например,
Filled with Live: Can be used only by Living creatures.
и для нейтралов:
Neutral: Can be used only by Unaligned creatures.
Заменил.
P.P.S.
Предлагаю прорабатывать по пять шмУток за раз. 5 довели до ума, следующие пять и т.д.
2Skay
Было бы очень хорошо. Перечислю что надо: шаблоны карточек (Item Stat Cards, Stat Cards), шрифты (включая символьные для атак) и шаблоны сценариев (ОЧЕНЬ желательно в .indd). Ну и все это в печатном качестве. Хотя я не уверен что они согласятся. Но в принципе должны были сами раздать это все добро Chapter Master'ам. wink.gif Даешь GNU/GPL в DDM! ))
сообщение 13.9.2009, 15:14
Переработал карточки. Понизил Max. Level многих карточек ввиду его неадекватности wacko.gif . Point Cost - вычислил по системе: Min. Level + Max. Level, в случае если полученное значение слишком велико для предмета: Point Cost = Max. Level.
Так как я сам не могу протестировать карточки (на данный момент - нескем поиграть), был бы очень благодарен если бы нашелся такой доброволец. Если есть предложения - говорите, выслушаю.
Изменил названия некоторых карточек и способностей.
сообщение 14.9.2009, 1:18
На мой взгляд такие шмотки будут играбельны либо в эпик форматах , либо в спец. сценариях.
Уж больно дорого шмотки стоят, я думаю пользы от лишней кричи будет больше.
Или кто приведет пример убер банды на одной из шмоток?
сообщение 14.9.2009, 14:38
Думаю это больше подойдет для Epic. Min. Level - и так не очень низкий. Хотя, кто знает, у каждого свои методы. smile.gif. Mirror Shield и некоторые другие, в принципе подойдут и для 200. Я думаю кошмар анти-Undead банды - Mirror Shield и его разумно вешать на кричу с наибольшим Vulnurable Radiant, так как: "attacker gains radiant Damage equivalent to radiant Damage dealt" wink.gif. Cleric of Pelor - будет не рад. happy.gif
Я теперь Хранитель. Круто.
P.P.S.
Например, на основе Spiked Crown можно собрать банду крич со всякими бонусами по отношению к окровавленным целям. А Soulkeeper Amulet можно одеть на крутую кричу, и подобрать для нее помощников с Heal. И т.п... Вариантов - много...
Текстовая версия Сейчас: 27.10.2025, 8:28
