> Альтернатива лизардменам (lizardmens), Где искать?
сообщение 7.8.2010, 22:40
Многие задаются вопросом чем можно заменить ГВшных лизардменов (lizardmens) ?
Мы знаем несколько ответов :
This is a pack of 3 Troglodyte models, sculpted by Jo Brumby, and cast in pewter. The 3 figures are multi-part castings, and they measure around 32mm to the eye. They are armed with a stone axe, wooden club and a pair of javelins. They are supplied with square 25mm plastic slotta-bases.
This is a trio of unarmed Troglodyte warriors, sculpted by Snuurg. They stand at around 30 - 31mm tall to the eyes. Each model has a seperate tail piece and one has seperate arms. Supplied with 25mm square plastic bases.
This is a pair of Troglodyte command figures; a Chieftain and a Shaman, sculpted by Snuurg. The Chieftain is a multi-part model with seperate arms, and they stand at 31mm and 34mm tall. They are supplied with 25mm square plastic bases.
This is our first pair of Lizardman Warriors. They measure 27mm and 29mm from ground to eye (but they would stand around 35mm tall if standing straight). They are multi-part castings, so some assembly will be required, and they are supplied with 25mm square plastic bases. Further head and weapon variants will be produced soon, as will a Lizard King figure. The pictures show the sculptor's master models.
Естественно, мы готовы помочь с приобретение альтернативных лизардменов (lizardmens) вместо Гвшных
Armasegara
сообщение 17.6.2011, 18:46
Из: Петербург
Пользователь №: 758
Дополнительно - есть совершенно обалденные модели ящеров от Reaper, в серии Warlord если не ошибаюсь.
В качестве альтернативных кроксигоров можно взять крокодилов от Crocodilegames.
Текстовая версия Сейчас: 25.10.2025, 13:26
